shake your head NO- up wake
do you really think that this will improve Volumetric Efficiency or reduce suction throttling loss
shake your head no
do your really suppose that there is there any way that your tampering can improve anything ?
shake your head no
why do you persist with what you have been shown can not function As you desire it to ....
you can not "hope" for an improvement , you must operate in
reality , unlike our current government
up wake
Originally Posted by suspectnumber961
As a TEST...I installed this block in my Focus intake. Weather won't permit testing a full tank...this was just a test to see how it runs. Runs about the same...anyone not knowing it was in there...wouldn't likely be able to tell the difference.
Made of a heavy plastic funnel...just forced it into the corrugated part of the intake tube after the MAF.
Opening in cone is around 1 1/4"...which is approx the same as a half throttle opening (45*) at the throttle body...so in most situations it just acts like a dirty filter ABOVE a certain throttle opening? Used around .61 square " per L from above posts as a guide.
Scangauge shows high mpg for first mile on highway after leaving town...but it settles down after that.
Will reinstall and test next summer.
Reason: as spelling
