Gealii, I don't understand how I would use the template for the underside. Here's a picture of RAVadoodle flipped upside down. And the original too. I tried to use the template, but it wasn't making sense.
I also added the approximate location of the belly pan. The sides of the RAV, below the doors, has a little plastic lip. So what you see, isn't necessarily what you get.
(A level spot, from front to back, not side to side.)
The main parts of the belly pan are pretty much finished.
Because I was running out of large coro pieces, I used scrap to finish the wheel well area. It wasn't quite long enough. I have an idea for sealing up the wheel well area, so it'll get fixed later.
It was getting dark. The pictures aren't very good, but hopefully well enough.
The middle of the back, about 12" in, sags around 2". I want to add a bracket, or something to pick it up at least 1.5" - 2".
Edit: Pretty goofy looking!
