Old 09-28-2012, 11:58 AM   #265 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Weather Spotter View Post
I got one side done for a comparison. When I put it into reverse I get running lights too ? still figuring that out. Running lights on, does not turn on the reverse lights though. so I am unsure where the crossed wires are. my old way did not have this issue and I hooked up to the old wires in the same way ???? something to figure out tomorrow after work.
Did you get this figured out yet? It may not really be a problem to have running lights come on with reverse lights. Are the reverse lights LED too? I had a wild thought that perhaps the LED tail lights share a ground with the reverse lights and perhaps a little current is coming to them through the ground connection?? Just a thought...
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
