I've been working on it I got it such that the reverse lights don't trigger anything else but I do have it so when i blink the right turn signal the right one blinks nicely but the left DRL's nightlight running lights come on a little bit not all away but they come on someone what.
Think I have a little bit of cross wiring in the old trailer lighting adapter kit and I think that is where my slight voltage leak is coming from the turn signals over to probably the brake lights rather than the nighttime running lights.
I am Planning on tonight taking the adapter plugs that T off the lighting harness Where i cut into them to put my trailer lights unplugging all those. then going to wire right into the OEM wiring harness and seeing if that will illuminate the crosstalk.
I might even get some picks posted
