Use gear oil.
Ok
Sounds pricey. I have been using a $17 charcoal filter for an RV and a $9 calcium neutralizer for water mist systems on my pressure washer and it has cut down the spots quite a bit.
Both filters have garden hose connectors.
I have a pair of cartridges that were free, I just have to come up with a housing (and bypass for normal mode).
Above would be attractive if I didn't already have free stuff.
I hope you got a liquid filled gauge or at least use a pressure pulse dampener.
Because the needle on a regular dry gauge will bounce all over the place.
Gauge is Glyceryn filled, intended for pressure washers. Works well btw. $25 ish from Amazon, prime eligible. Edit : here is the gauge.
http://www.amazon.com/gp/product/B005QZ4A1E/ref=oh_details_o01_s00_i00
Total "cost" just broke $50
