I've read in plenty of places that straight cut off edges, especially from side to top, or in this case bottom to side, is not a good thing. So the "box" isn't staying. I'm actually planning a complete redo of the entire middle to back belly pan. I've learned a ton by getting in there and doing it. But I want it as level as possible, and easier to remove if needed. I also don't like the openings for the exhaust pipe. Even with a grate to act as a wind block, I can just imagine all the snow I'll be scooping up in there. It will melt with all the heat, and then freeze later in the many low spots. What a headache!
I'm thinking it will be worth the exchange of 1" lower belly pan to have enough clearance around the exhaust pipe, to not have the openings. And I'm going to be persistent in getting some 4'x8' sheets of coro. That will put me 2" short on one side, but I'm sure I can make it work.
But back to the task at hand. I need to figure out this back end part, and especially get all the wheel well areas sealed up before Winter is here!
I need some help deciding what to do with the wheel well areas. On the first rear wheel well area that I added coro to, the top part of the opening, for the suspension bar, is crinkled. Like the bar didn't have enough room. I thought it would be enough, but obviously I need the entire factory allowed room. The problem with that, is allowing room for movement means there's larger openings for snow and what-have-you.
1. Most promising idea. Is using a long/flat rubber piece, attached vertically to the coro on either side of the suspension, so the bars can move freely between. But stiff enough to keep snow out. Kind of like the cover for an auto with the shifter on the floor.
2. Another thought I had this morning was to make an inward curved shape out of coro. Hopefully that would keep the majority of snow out of the main parts of the belly pan. By having it curve in, I would be able to go through a section of the suspension that wouldn't move as much as it does by the tire.
3. And lastly I was thinking of attaching one, or a couple of pieces of coro to the suspension bars themselves, that would move up and down with the suspension, and hopefully close off the openings enough to keep snow out. Least likely to work, because of room restrictions for the moving coro piece, and attachment to the bars.
Another area I need some help with: The wheel skirts. My original plan was quite simple.
But now, I'm thinking I'd like to make the belly pan wider in the back, curved, and lined up with the future wheel skirts. Here's a VERY rough draft:
The area in front of the wheel, down low, looks difficult. Gradual is better, so I'm wondering if some side paneling would be a good thing? Like BamZipPow's, but not as low. Like I said, I don't want to lower RAVadoodle much, if any. But they might add as a better transition?
I'd consider "loosing" the rear side bumper pieces. if it would be better.
I'll keep searching around for ideas/answers. Any that you guys want to directly add (or even helpful links), is always HIGHLY appreciated!
