I added a quick connect between the lance and nozzle so I could easily swap my foam cannon in/ out.
This has a real downside with the adjustable angle nozzle, when you rotate the nozzle nothing happens, so I whipped up a handle on a 3d printer so I can both pick nozzle angle and adjust spray angle as well.
I also drilled my nozzle to 1.72mm, definitely to big, but it does have the advantage of being able to eliminate bypass entireley without fear of tripping the overload, unfortunately washing pressure has fallen to 850 psi, but with the increased volume it cleans as well or maybe better, particularly when rinsing.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
