Old 09-30-2012, 07:09 PM   #5 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I might just have to try this myself!
Hinge it at the front and then use a short wire rope to hold the other end. the sides could be made a bit wider then the tail and just slide past the outside (or into a pocket). this would not work for snow but might be a quick test.
Flexible sides could be made of stiff rubber. They could be made to fold in as the bottom folds up.
Whats the ideal angle for the bottom?
The Following User Says Thank You to Weather Spotter For This Useful Post:
HydroJim (09-30-2012)
