Old 10-01-2012, 01:43 AM   #584 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Cd View Post
If you have detached flow along the bottom of the tail and are concerned about lowering the angle due to scraping on ramps and such, you could always just create a hinged section that hangs down.
If it's light enough, it'll show the correct angle the air wants
OTOH, I think Sven7 is quite close - those last few inches aren't going to ruin it.
If the lower end can't be lowered, maybe a small gurney-flap / fancy name for an L-shaped bracket / will do the trick.
