is it the original clutch? was the engine hot when it happened? sounds like the clutch disc maybe froze in between the flywheel and pressure plate due to the extra torque. maybe from heat? i would go on the same hill again but this time pull out normally in 1st and see if it acts up again. if not i would keep driving it
