D.D. Sorry to hear about your trouble. Your Truck should have an inspection cover below the bell housing and in front of the trans ,pull the cover before the weather changes, a strong flashlight will help you see the damage! measure the clutch thickness . you may have just saved yourself a few $ and a tow job. The former owner more than likely started the problem and now you have found it. keep us posted
