Old 10-02-2012, 12:08 PM   #15 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by sheepdog 44 View Post
Thanks for the info. I suppose with all things if you just happen to have a spare or free o2 tank and you can get really cheap refills thats great. 2-10% efficiency across the whole range, more HP, and better emmisions. As long as you invest little, what more or less you gain gives a faster return on that investment.
I guess why this isn't standard stuff is it adds consumer involvement in the refueling process. And leaking LPG or o2 in a crash isn't so good. Not that the tank will rupture, but what safety disconnects will you have that stops leaking the gas on impact?
I don't remember the exact details, but I believe the Argonne system had the technology to chemically change the incoming air onboard (no high pressure O2 tanks). The details are in that link.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
TDFbound (11-22-2018)
