Old 09-28-2012, 11:12 AM   #11 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by sheepdog 44 View Post
So if piping LPG into your engine helps (whether for power or FE) what about piping pure oxygen? An ember in pure oxygen will burst into a fire, and gas would presumable burn cleaner. Say just double the atmospheric percentage of o2.
I've always wondered what would happen if you drove a car in the prehistoric dinosaur era when they say we had a much richer oxygen atmosphere.
I think you just answered your own question, think about it.
I'm not coasting, I'm shifting slowly.
The Following User Says Thank You to UFO For This Useful Post:
TDFbound (11-22-2018)
Old 09-29-2012, 02:05 PM   #12 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
The propane injection sounds like a fun project really,if it delivers more miles a gallon and more hp it is on the verge of unbelievable,yet much like the x-files i want to believe.. I can see the reasoning behind the reported benefit of the enhanced burn it may/would cause.
Save gas
The Following User Says Thank You to ecomodded For This Useful Post:
Old 10-01-2012, 02:36 PM   #13 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Oxygen "enrichment" has been done by some folks at Argonne National Labs:Clean Diesel Technology.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 2 Users Say Thank You to Diesel_Dave For This Useful Post:
sheepdog 44 (10-01-2012), TDFbound (11-22-2018)
Old 10-01-2012, 05:27 PM   #14 (permalink)
Thanks for the info. I suppose with all things if you just happen to have a spare or free o2 tank and you can get really cheap refills thats great. 2-10% efficiency across the whole range, more HP, and better emmisions. As long as you invest little, what more or less you gain gives a faster return on that investment.
I guess why this isn't standard stuff is it adds consumer involvement in the refueling process. And leaking LPG or o2 in a crash isn't so good. Not that the tank will rupture, but what safety disconnects will you have that stops leaking the gas on impact?
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
Old 10-02-2012, 11:08 AM   #15 (permalink)
I don't remember the exact details, but I believe the Argonne system had the technology to chemically change the incoming air onboard (no high pressure O2 tanks). The details are in that link.
Diesel Dave
The Following User Says Thank You to Diesel_Dave For This Useful Post:
Old 10-02-2012, 06:46 PM   #16 (permalink)
MPGs with propane?
Yeah it works, propane just replaces diesel fuel.
After testing on and off for about a year I figured propane on a suburban was too much of a hassle.
The plan was to experement with propane then test water and water methanol injection.
Well I tested the propane, didnt much care for it and never got around to testing the water and water/methanol till 2012.
Wished I would have followed through with water and water/methanol testing or tested had tested it first.
I like the water based system better than the flameable gas based system.
The problem with high compression diesels and propane is if you add too much propane you get detonation, which will ruin the engine pretty quick.
I injected water/methanol (80proof) l mixes with enough methanol at high enough volume on several runs to make around 150 horsepower (had there been enough air to burn it) with no knocking.
The suburban took off like a bat out of hell and left a good cloud of smoke.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Isaac Zackary (09-20-2016), TDFbound (11-22-2018)
Old 09-20-2016, 05:11 PM   #17 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Ok. So I'm seriously contemplating this for my 1.6L non-turbo 23:1 CR 1985 VW Golf diesel.
I consistently get about 55mpg gallon already on the highway. But perhaps what I'm more interested in is reducing emissions, black smoke, etc.
Any thoughts? How would this best be hooked up?
One problem I foresee is that on the Golf the air cleaner is in the top of the plenum. So if I add propane it would either have to be before the air cleaner or into each intake runner or I'd have to relocate the air cleaner.
Also this is mechanical injection. So I can't meter propane electronically by taking data off of an EFI system.
The Following User Says Thank You to Isaac Zackary For This Useful Post:
Old 09-20-2016, 06:06 PM   #18 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
There are "illegal" systems that inject CNG instead and can include their own electronic crapola.
Personally I would not waste any effort on LPG unless it were nearly free (which it usually isn't in the US)
CNG is cheaper in most areas and cannot detonate.
Still likely a long payback.
The Following User Says Thank You to rmay635703 For This Useful Post:
Old 01-15-2017, 07:02 AM   #19 (permalink)
teoman's Avatar
A3 - '12 Audi A3
How about LPG plus water. You could maybe inhibit the detonation with water.
Also, could you inject the lpg with a gasoline injector? That would make it much easier to control for us computer oriented guys. I suppose one could have to read the pressure and the temperature of the lpg before injection.
Also the evaporisation of the lpg would further cool the intake charge.
The Following User Says Thank You to teoman For This Useful Post:
Old 01-15-2017, 08:13 AM   #20 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I'd like to know the long term effects of regular use, preferably on different types of engines. Not much point to saving a few bucks in diesel if you'll be replacing your engine within 6 months.
And would a small dose be beneficial to the combustion process without the risk of knocking?
The Following User Says Thank You to Stubby79 For This Useful Post:
