Old 10-03-2012, 02:46 PM   #9 (permalink)
redneck
Originally Posted by LeanBurn View Post
I would modify the variable that yields the greatest gains that cost the least first.
1) driving habits
2) tire pressure
etc...then move to mods that cost, that may have a lesser effect.
+1
Read
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Then
65+ Vehicle modifications for better fuel economy - EcoModder.com
Since your car is a 1995, it is pre OBDII. You can not use a Ultra Gauge or Scan Gauge mileage computer. You can however use a MPGuino sold here on this site. You would have to splice it into your wiring harness. It is not hard to do and gives you a ton of feedback. At the very least install a vacuum gauge to help you figure out if what your doing is a plus or minus.
http://ecomodder.com/forum/showthrea...able-6914.html
The best thing you can do to improve your mpg is...
Adjust the nut behind the wheel...
