Old 10-04-2012, 08:51 PM   #128 (permalink)
bobo333
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Thanks guys,
Im still saving for new gears, being such a popular diff they are quite expensive here, even from the wreckers they wanted $400 for a used center with a different ratio, then i still need to rebuild it with new seals and fluid and put it in
There is no overdrive which makes things worse, i have looked into getting taller tires to help out until i can afford a new diff center but tires this size are also quite expensive
I havnt yet kicked the speaker on the drivers side (there is about an inch and a half to the pedal) but i am working on a grill to put over it just in case.
Thanks for looking
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
The Following User Says Thank You to bobo333 For This Useful Post:
Ultra-Orange (10-05-2012)
