Old 10-05-2012, 08:51 PM   #593 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
ja ja ja
I think I may remove the huge belly pan. It's just causing problems. Hanging down on the edges, no real way to secure it in the middle, hanging down in back. The pass. front corner unhooked itself on the road a few days ago. Just a general pain in the butt. I'll probably pick up some lawn edging for an air dam and go that route.
I'll keep everything from the rear beam back, and from the firewall forward. The rest, ugh. No. Is it worth tufting for attached flow on the bottom of the tail if I dont' have a full pan?
Also, this thing needs a front pass. wheel bearing, like, last month. It goes "wee wee wee wee wee" down the road everywhere. Going to call The Alignment Guy and see if I can't get tie rod ends and a front end alignment done at the same time. Problem is I don't have a ton of money at the moment either.
