I changed my front wheel bearing when it went Gurrr....Not too difficult, I changed the whole knuckle got one from the junk yard with a good bearing in it. Did the wheel alignment with string for minimum drag, zero toe in. There might even be a how to video on youtube by Rich Pin. Make sure to check the loose nut behind the wheel.
- Tony
