Old 06-10-2008, 09:29 AM   #11 (permalink)
ttoyoda
ttoyoda's Avatar
Guys, it's mostly Ford and Honda that spec 0/5W-20 oils ... and I don't think they redesigned a single engine with this thinner oil in mind. All the engines that call for it are older designs with the same clearances as when they called for 5W-30 (like Dad's Mercury Grand Marquis with its 4.6L V8).
Let us assume you are correct. Why then were these engines specd with 10w-30 to begin with if the bearing clearances are unchanged? I can tell you why the spec was changed to 5w-30: To improve fleet fuel economy to meet govt. standards. As long as the engine outlasts the warranty, it is not the manufacturers problem.
