Old 10-07-2012, 10:55 AM   #239 (permalink)
Uncle Dave
This is correct. Or could you hold the magnets, and coils close to the teeth.
OK, like they to the Timing. But this time not a small sensor, but with a stronger pulse. The old water wheels were a full ring around the central disc. We are not powering a town, but just one car, that is using a minimum load.
You are correct, there will be some machining, and location problem. Should be able to be on the engine casting, not the wheel its' self. On the wheel its' self would make for Ballance problems.
You have the idea. You are making a tack, but a wee bit larger.
