Old 10-07-2012, 05:44 PM   #81 (permalink)
SeniorSell
Dave Upton
Smile Shunt information
Originally Posted by rmay635703 View Post
Yes the length is very important, my 48v motor requires about 12 FEET, a 72v motor would require more in general.
Ryan, Is your shunt simply a bare coil of wire in open air? A coil as if you wrapped the copper wire around a circular object until the length was the correct omeg value? Or did you wrap it with 3M 130c rubber tape and insulate it? I guess a picture would be great if you had one. Thank you,
Dave
