Old 10-09-2012, 10:27 AM   #14 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Glad you tufted the leading edge of the hood. Despite the car's "blocky" front end appearance, those relatively small leading edge radii really work to prevent flow separation.
Originally Posted by christofoo View Post
I'm just polling for (dis)agreement here before I finish this up tonight.
It seems that an angled airdam that lowers the stagnation point makes sense. Haven't seen any hard data or testing against a simple vertical dam though.
BTW, the under-body clearance is about 6", so I'm shooting for about 5.5-6" air dam clearance (probably 6" toward the middle and 5.5" toward the wheels). I'd rather err on the high side if I must err.
Why err high? Do a mockup with cardboard: go aggressively deep (say 3 inch clearance) and compare to 5.5-6 inch clearance.
I went very deep (3 inch clearance) with the air dam mockup I tested on my Firefly which has similar ground clearance to your Corolla. A-B-A coastdown testing seemed to show an improvement. I did not try a shorter version though.
http://ecomodder.com/forum/showthrea...down-9732.html
