Originally Posted by orion411
Additionally there is an implosion happening in the cylinder on the intake stroke. You could call it negative pressure supercharging. So the whole process is like peddling a bike with clip in shoes. You got force pulling and pushing on the piston equally.
Really? Since the piston has pushed most of the charge out of the cylinder, what is imploding? And if it is, it would produce an
upward force on the piston,
reducing power, not increasing it. Do you even understand how an internal combustion engine works?
