Old 10-09-2012, 07:38 PM   #7 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Formula413 View Post
Since my weakest one so far was 6,252mah, and that after four cyclings, would any additional capacity I can coax out of the stronger subpacks be essentially useless?
Yup. The pack capacity is limited by the weakest subpack.
B. Has anyone else found that the Superbrain is not capable of sustaining the 10 amp discharge rate recommended for cycling? On mine I can start a discharge cycle at 10 amps but the internal temperature regulating software seems to reduce it to about 5.3 amps after a few minutes.
I didn't see this, but I had a second cooling fan duct taped right on the vent area of the unit helping to draw air through it to aid the internal fan, not just blowing at it.
