Old 10-10-2012, 12:33 PM   #69 (permalink)
seeodywhy
Originally Posted by turbovr41991 View Post
It is just two numbers and really easy to do. They have a spreadsheet with the input numbers listed by car type. Pretty simple.
Then you might need to calibrate of fine tune it. Make sure your miles match a GPS and then check your fuel usage when filling up!
I checked the wiki and it doesn't have the hx listed. Can you share what values you use? I wanted to install this today but I am having trouble finding that values. Also, did you have adjust the values you used much from the original.
