Check your tires! (pressure... getting cold!)
Just a friendly reminder to check your tire pressure. And don't forget that tire in the trunk, you may need it some day.
It's cooling down outside, and my tires were all down at least 5psi. However, I had two down 30psi! Fortunately one was the spare, the other was a rear tire that I guess I need to watch a little more closely. At 10psi, it had surprisingly little deformation; I guess there just isn't that much weight on the rear tire of a Civic.
