thanx for the info TurboVR! yeah, i think i will end up removing the power steering system, but thats down the road. I can get the car to go into lean burn sometimes, but only very briefly. i still have a California spec ECU, which makes it hard to get to lean burn, and hard to stay there. but judging by the fact that my #2 o2 sensor goes to "0" sometimes, that is a tell-tale in-lean-burn-indicator. sure would be nice to get a 49 state ECU, and remove power steering, then i could get into, and stay into lean burn waaay longer
OK well, I got the hood lip done FINALLY. damn it took a lot more man hours than I expected to get it all smoothed out, but its done now, as are a couple other cool mods i've done since then... so check it out! also see that i got these sexy ~9.5lb civic VX rims! oh yeah!
btw: i'm averaging about 54mpg over a whole tank now, about 80% freeway and 20% streets. I have an engine cut off switch installed, and do lots of P&G
first the hood lip. as you can see i've also removed the stock external antenna (i have an interior antenna now). I still need to sand and paint the hood, but that'll happen later. aesthetics is not a high priority with this car - well, actually, its not at all a priority hahaha
HX pride!!! wooot!
2000 Honda Civic HX with mild aero mods
2006 Honda Insight MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
