Old 10-13-2012, 11:10 PM   #247 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by brucepick View Post
I could foresee some issues if switching while engine is running - though I think California98Civic has been doing that for some time, via the control harness wire(s). In my case I only switch it with engine off.
You got it right, bruce. But I don't do this a lot. Generally it is off for the trip, or on for most of a trip, depending on distance. I have not yet encountered any difficulties with the ECU. Maybe it's worth noting that the ELD in these Civics already varies the voltage quite a lot, when operating normally. Under certain conditions with the alt running you see instantaneous jumps from 12.5-14.xx--with amperage jumps too, I think--and all of it regulated by the ECU as Honda designed it. So it seems logical to me that manually switching from a scenario of 12.5 volts to 14.xx shouldn't pose problems. But I am neither an engineer nor a mechanic. I just own a Civic that I hack-up and repair as best I can.
