any revision or restructuring or ground built prototype, can and would need a seperate patent to be legit to that specific design... while there have been others to make this same type of system, they are not equal.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
