The only way to actually test if they would work would be to use a generator get it to full temp shut it off. Then have the different mixes ready in separate containers and run each container empty and log the run time. Although that will not give you results for a car.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
