Old 06-10-2008, 09:12 PM   #159 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Yes I actually got enough lug nuts finally and all the wheels are properly bolted on
I like those tires they are Sumitomo HTR 200 175/70R14 LRR tires. They fit the fenders perfectly The might rub a bit but that is what a sledge hammer is for. If it rubs the fender lip I will just chop it off probably. The car is now like 10 inches off the ground and I could climb under it easily without jacking it up so I am going to have to cut the springs way down. Probably 2 coils to get it back to normal. I have to find a 16 tooth speedometer gear to get it accurate but I can pick that up from a suzuki dealership sometime since they probably aren't easy to find in junkyards.
