Old 10-19-2012, 11:42 AM   #16 (permalink)
Firestarter
Originally Posted by Ryland View Post
A topped off battery is going to save wear and tear all around, it's going to put less of an electrical load on everything because there will be slightly higher voltage, it will also make the engine spin over slightly faster causing it to catch sooner and be at a higher speed when it does catch.
Really I don't see any draw backs to plugging your battery in to a charger, it might not be worth it to you to do it every single day but once per week if you do a lot of short trips or a few times per year and you will end up saving money in other parts of your car, not just saving in gas.
Not necessarily true. Every car I owned cranked over the same unless the battery was low or ice cold. I've even upgraded to higher amperage batteries and still same cranking duration. Perhaps it its relay prevents ultra high amperage from reaching the starter.
Personally I think you would get more of a benefit from solar panels
2013 WRX pbp sedan
2009 GSX-R600
1998 Ram 2500 CTD 2wd 5spd (sold)
2009 GSX-R1000 (stolen)
2010 Tacoma 4x4 6spd (sold)
2006 WRX/STi obp sedan (sold)
2009 GSX-R1000 (crashed)
