Old 10-17-2012, 03:33 PM   #11 (permalink)
Originally Posted by PaleMelanesian View Post
I EOC so much, the alternator has no chance of keeping the battery topped up. A few cents of electricity is cheaper than the dollars of gas consumed by leaving the engine running.
Eoc? Start and stop the motor I'm assuming.
2013 WRX pbp sedan
2009 GSX-R600
1998 Ram 2500 CTD 2wd 5spd (sold)
2009 GSX-R1000 (stolen)
2010 Tacoma 4x4 6spd (sold)
2006 WRX/STi obp sedan (sold)
2009 GSX-R1000 (crashed)
Old 10-17-2012, 03:47 PM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Right. When you're Engine Off Coasting, the engine's not turning, so the alternator is also not turning or charging.
Old 10-17-2012, 03:54 PM   #13 (permalink)
I've done that on street bikes... but that's cause the motors are so roll restrictive.
2013 WRX pbp sedan
2009 GSX-R600
Old 10-17-2012, 04:51 PM   #14 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I guess I'm convinced now -
It's a case of different strokes for different folks.
I think it's mostly a matter of what your skills are and what type driving you do.
Coast long and prosper.
Old 10-18-2012, 12:41 AM   #15 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
A topped off battery is going to save wear and tear all around, it's going to put less of an electrical load on everything because there will be slightly higher voltage, it will also make the engine spin over slightly faster causing it to catch sooner and be at a higher speed when it does catch.
Really I don't see any draw backs to plugging your battery in to a charger, it might not be worth it to you to do it every single day but once per week if you do a lot of short trips or a few times per year and you will end up saving money in other parts of your car, not just saving in gas.
Old 10-19-2012, 10:42 AM   #16 (permalink)
Not necessarily true. Every car I owned cranked over the same unless the battery was low or ice cold. I've even upgraded to higher amperage batteries and still same cranking duration. Perhaps it its relay prevents ultra high amperage from reaching the starter.
Personally I think you would get more of a benefit from solar panels
2013 WRX pbp sedan
2009 GSX-R600
Old 10-19-2012, 12:13 PM   #17 (permalink)
Ryland's Avatar
Yes you would, a solar panel would also be in the category of trickle charger and people who I know who have had solar panels keeping their batteries topped off, including two of my parents vehicles, have found them to help keep the battery healthy and from needing to be replaced, paying for the cost of the panel right away.
Old 10-19-2012, 05:37 PM   #18 (permalink)
How much mpg did they gain?
I should make a spoiler out of panels for my WRX... hahahaha
2013 WRX pbp sedan
2009 GSX-R600
The Following User Says Thank You to Firestarter For This Useful Post:
Cobb (10-20-2012)
Old 10-20-2012, 07:23 PM   #19 (permalink)
I purchased 4 panels from ebay to mount side by side to do just that for 48 volts for my engine phev kit. Question is, how much mpg will the wing cost me and is there such a thing as a zero drag as the mugen aftermarket wing claims?
