Old 10-24-2012, 02:40 PM   #81 (permalink)
Otto
Originally Posted by AndrzejM View Post
I'll try to do that and see what i can do with original bumper cover. Thanks.
I don't want to lower Berta, she's low enough for polish roads
I think I'll go into the air dam direction with belly pan, because I want to flatten the belly of Berta. You can see here Three levels of Berta's belly that there are few things that can be improved.
I'll try to find some details. But I have ducts from the front to the wheel arches, but those are for cooling the breaks.
You could use the holes for the fog lights to make ducts to feed the air curtain. Better, though to have ducts off the center cooling hole. (Less drag because the center hole is at the stagnation point so has greatest pressure, but out at the fog lights the air is accelerated, so holes there would make more drag.
The Following User Says Thank You to Otto For This Useful Post:
pRoy (11-28-2012)
