Old 10-24-2012, 04:29 PM   #13 (permalink)
mort
EcoModding Lurcher
mort's Avatar
On paper the otto cycle can be up to 73% efficient (if I remember correctly) so it would be nice to see how this one does in the real world.
Otto cycle efficiency is related to compression ratio. In theory the Otto cycle can get as close to 100% efficiency (but less than 100%) if you run a high enough CR.
If you include the slight advantage of having a larger expansion ratio, 75% efficiency requires a CR of about 30:1, Which I think is going to be expensive to deliver with the durability expected in modern machinery - considering those sliding seals, especially the end down by the axis. Mazda always had trouble with those seals.
-mort
