Old 10-23-2012, 10:03 PM   #1 (permalink)
Liquid Piston? 40Bhp 75% Thermal Efficiency
LiquidPiston unveils 40-bhp X2 rotary engine with 75 percent thermal efficiency
http://www.gizmag.com/liquidpistol-rotary/24623/
Old 10-24-2012, 01:55 AM   #2 (permalink)
On paper the otto cycle can be up to 73% efficient (if I remember correctly) so it would be nice to see how this one does in the real world.
Ryland (10-24-2012)
Old 10-24-2012, 03:38 AM   #3 (permalink)
Very interesting. Very very interesting. I wonder if it will make it into the production phase? Have seen a lot of "revolutionary" motors stall in the transition to commercial production due to lack of investors and interest.
Old 10-24-2012, 03:40 AM   #4 (permalink)
Send a message via MSN to markweatherill
' In current ICE engines, an alarming amount of fuel goes out the tailpipe. '
I've seen similar statements used to advertise other miraculous advances in technology.
I don't know if it's the manufacturer or the article writer, but it doesn't add any credibility to the product in question.
Old 10-24-2012, 04:06 AM   #5 (permalink)
I agree, they are only hurting them selves.
Old 10-24-2012, 06:11 AM   #6 (permalink)
90 day: 29.78 mpg (US)
Count me as a skeptic. Some of the language as pointed above raise red flags as to the credibility of the invention. Why wouldn't the engine be suitable for primary transportation? The article seemed to say it is only suitable as an APU. Perhaps it suffers from poor performance or longevity at varied speeds? If so, then it would be suitable as a series hybrid electric engine.
Old 10-24-2012, 09:44 AM   #7 (permalink)
I think Argonne Labs is approaching 60% efficiency with a mostly conventional otto cycle engine. I think it should be obvious that when you start throttling any engine to control speed in a vehicle, you can forget any efficiency in even half that range, which is why vehicles will neeed high efficiency capacitive energy storage and IVT transmissions to separate the engine from directly powering the vehicle.
Once this is accomplished all energy consuming primary power sources will be able to provide power to drive the vehicle.
regards
Mech
Old 10-24-2012, 10:33 AM   #8 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
LiquidPiston ::
57% efficient in real life is their goal.
Old 10-24-2012, 12:27 PM   #9 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
“Everyone would say at first glance that the diesel engine is more efficient (than the petrol engine). The truth is that if you had both engines at the same compression ratio, the spark-ignited engine has a faster combustion process and a more efficient process. In practice, it’s limited to a lower compression ratio otherwise you get spontaneous ignition.”
That is one of the stupidest statements I have read. Duh if you take away the benefits of running diesel the gas engine will be better.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 10-24-2012, 01:36 PM   #10 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
With the lack of detail regarding whats its capable of, RPM rates, Tq isn't even included with the peak 40HP claim. I don't see this as much more than a generator like it steers toward with its description.
Someone mentioned in the gizmag comments about "not being RPM variable friendly" and another saying might "operate within a narrow power/rpm range".
Even if it operates decently within a givin power/rpm range, one could retain the use of the existing transmissions and low gearing for the low RPM variable diesel engine it could replace.
Unlike ICE having a small boost in FE when properly tuned with a turbo, it would be interesting to see the outcome of a turbo model of this "New Cycle" with regards to fuel consumption, heat, peak power/Tq?! ...If it ever comes to light. Maybe I'm over shooting what this engine is capable of though.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
