Hello Mark,
YES, I believe that the modules will work perfectly. They have the same gate terminal spacing as the 400A modules. They are .71" wider in total though but I believe the spacing is adequate to make them fit. This driver should be a drop on solution for driving those modules. Just need to tune the gate resistors for those.
Ive been wanting to order a panel of these, so if the market is there, I will place an order.
-Adam
