Originally Posted by euromodder
They're rare as hen's teeth ...
Usually with prices to match, which eliminates your profit right away.
Same goes for the Audi A2 3L - but the 1.4 TDi will do almost as good.
If you're on a budget, you might want to take a look at the Skoda Fabia (I) 1.4 TDi.
Bigger car, but it still does under 4L/100km with only moderate driving.
Hypermiling, you'll be looking at 3.5L/100km ... or better.
The newer 1.2L TDi is also good for FE - but will be more expensive.
Make sure the auto transmission is absolutely OK when you get a Lupo 3L - they're notorious for tranny troubles.
As with any TDi : belts need to be done on time.
If in doubt wether it has or has not been done : have it done anew.
Full VW service history is highly recommended.
Test-drive it until it's fully warmed up, shut off radio / AC / heating etc ... see it it kills the engine at standstill in N.
Thanks for the the Skoda recommendation! I had a look here in Switzerland for the 1.4 TDi, but it seems quite rare (much more 1.9 TD's available).
There are a few 3L's on the market here, but indeed I have been warned about the costs of repair. I hope to go for a test drive this weekend from a private seller.
And thanks a lot for the other suggestions - will keep these in mind when trying out the car
