your theory is not accurate
Originally Posted by suspectnumber961
First...I have no idea WHETHER this block will improve mpg...but I have reasons to believe it MIGHT.
The mod is easy to install and easy to reverse.
IF I do see an mpg gain...I MIGHT..........then........try to explain it.
Or better yet....I will let certain parties explain why it doesn't work after it does...as with the recent cone filter mod I tested.
PLEASE...remain as you are until testing is completed. Thank you....
i would be interested to see how you expect increasing suction throttling losses and decreasing volumetric efficiency are
supposed
to
improve
anything
especially,
fuel economy
specifically
BSFC at any load or rpm
here on the planet Earth in any car powered by an internal combustion engine .
ready
begin
Reason: your test will show you what most already know
