Well i got a sheet of 2mm Clear perspex and cut all 4 grills out to fit and im really happy with the 3 lower grill's you can hardly tell they are there at all and they look Factory fit which i what i was going for but the main grill i may have to look at again as im not 100% happy with that yet.
I ended up using black foam number plate sticky pads to fix the grill blocks.
I will get some photos up tomorrow for you to have a look at and make any suggestions.
I may end up getting a De-badged front grill so i can make a cleaner block.
