Old 10-27-2012, 06:52 PM   #10 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I have the same car and have been looking at this for some time. There are three screws that hold the fender liner in. One at the top, one low in the front and one high in the back. I cut and bent an aluminum piece that goes under the factory screw head and extends down below the fender lip to take a screw or Dzus fastener. That is as far as I got so I'll be watching your build with interest. Incedently, the fender liner bolts are right where Freebeard shows them in his illustration.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 3 Users Say Thank You to COcyclist For This Useful Post:
freebeard (10-28-2012), MetroMPG (10-28-2012), VWCw (07-23-2013)
