When I got the needle into the red I drove about 40 minutes on the interstate, through a suburb, and then went through some slow red light traffic. I don't know how hot it was but had to be at least 85F and above, no wind. When I do long highway trips I usually don't get over halfway on the temp gauge. Ill monitor it, but im not expecting much of a change with the air dam.
Im not letting it scrape, it did once with no damage. Im just worried it will pull and break a zip tie or crack the holes. Mine does lean out a bit, that's no problem, better then folding in I guess, I always see trans am class cars with with there's coming out a bit... I imagine it leans in a bit more while driving.
1995 ford mustang. V6, auto.
Mods. 2 inch exhaust with glass pack. some throttle body mods. cut up intake box.
Aero mods. Front air dam. wing delete.
