Old 10-28-2012, 01:37 PM   #21 (permalink)
freebeard
The forum software ate my lengthy reply when I clicked Preview Post. (grumble, grumble) Memo to self, copy before you click anything. Anyway...
You will need to lock down some decisions and not revisit them. Front engine = fiberglass body kit and a top chop. Mid-engine = cooler than poo.
Does the Metro use a rod or cable for the shifter? Mid-engine dune buggies have that all sorted out, look through their catalogs.
What are you using for your graphics? If it supports transparent layers, work over a side view of the real car and then turn the bottom layer off. You will see that your wheel/tire is way out of proportion. I know you asked for help with that. Without better specification, anything someone else might do will lead you away from where you want to be.
