Originally Posted by jime57
But, in the end you basically failed to get enough stable data.....
Jim, you're absolutely correct!!
My hand held GPS with a sample rate of .5 Hz and that the fact that it's readings are not very repeatable was the primary reason.
Attempting to get readings from the speedometer proved not much better.
Jim.
