Originally Posted by ps2fixer
You drive in a city environment right? Another thing to compare, I'm in the country, seems my car likes steady speed and long coasts to corners (in gear)  .
Good luck on reworking the air dam, make v2.0 a better design and I might copy you  .
My commute is about 10 miles by the way, ~70% freeway, ~6 stops. That should be a pretty good prognosis for MPG, but warmup eats this car, and winter is coming. (EDIT: I park it outside.)
