Old 10-30-2012, 04:40 AM   #8 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by Sven7 View Post
If you're removing the top, why not extend its sides down to the cargo floor level? Then you could attach the top half to the stock hinges/struts and take advantage of what's already there.
This would almost certainly have to be rigid- fiberglass or something. Maybe a rigid structure with all the panels made of clear acrylic or lexan
Great idea.
The main issue here being weight.......unless the tail was made from Coroplast ( Which i intended to do by using sections of the stuff for complex curves )
