Old 10-30-2012, 09:41 AM   #22 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by mrsilent13 View Post
well i am running 225 55 16 i guess going a size up on the rears and leaving the front stock would not affect it too much...or do i need to swap all 4 tires for the taller size?
General Altimax HP
Went to tirerack.com and pick the General tire ONLY for SPECS.
225/55/16, 25.7" diameter, weight 22lbs, 9.2" tread width
225/65/16, 27.5" diameter, weight 25lbs 9" tread width
both fit the same rim.
You need to make sure the taller tire wont rub the bottom of the front strut mount. I think I post a pic on my thread showing how close mine was.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
mrsilent13 (11-26-2012)
