Old 10-30-2012, 01:57 PM   #11 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by turbovr41991 View Post
I just opened egr passage block up. It took two nuts to allow the fuel rail to move out of the way, then maybe 5 bolts on the passage plate. After that I could quickly see it was the problem. There might be other ways to tell, but it only took me 5-10 minutes to get in there and look at it. I did a write up for the and linked to an even better write up with labeled pictures. Hopefully it is similar to yours.
You have to pull the fuel injectors from the rail and intake manifold to do this?? I'm asking because I still haven't done it.
Coast long and prosper.
