Old 06-11-2008, 03:48 PM   #10 (permalink)
jbrams
Commuting hypermiler
Bitty - '09 Toyota Matrix Base
90 day: 31.23 mpg (US)
Originally Posted by ttoyoda View Post
So it will just be getting broken in? I have 205,000 on my highest mile toyota alltrac wagon that goes on the road every day. My only problem is rust. Keep the oil changed often, thats the only secret.
Due for an oil change in 450 miles =)
I know it may be around still, but I also suspect that some minor transmission issues today may be major transmission problems in the next 50K miles, so longevity is good, but not the priority.
If you do a spreadsheet with the payback time of a gas-saving prius, you might be surprised how long it takes to justify the intial cost in terms of gas saved.
Well, I don't have the prius to include in my calculations yet - I'm planning on getting a new car in 2010, so it would be a 2010 prius (probable $25,000) or a used 2004+ prius (then maybe a cheap as $13,000). Part of my improvement will also be a much nicer car, though I love the Camry Wagon, it's not exactly the bee's knees nor a spring chicken.
I wish I had paid more attention to max tire pressure for a previous set of tires for another of my wagons: pirelli with a max of only 36 psi.
That was before I found this site, so I have *some* excuse.
Tell me about it.
Any one with specific knowledge about the BFG tires I mentioned in terms of which:
(1) will give me lower rolling resistance?
(2) has a higher max PSI?
(3) has less material (better for environment in shipping/eventual waste) and lower weight (less rotational mass)?
(4) has other good hypermiling attributes?
Thanks a million!
