Originally Posted by serialk11r
Maybe this is a horrid idea, but how about reducing the heat capacity of the cooling system?
It'd also cool off a lot faster.
Also, I suspect that engine oil has a lot to do with short trip economy,
It sure has.
I can see (instant fuel consumption), hear and feel the difference between 5W30 and 0W30 in winter.
Less fuel use in the first miles, and it runs quieter and smoother.
Supposedly not all 5W or 0W are equal, a 5W-20 is quite a bit thinner than a 5W-30 when cold.
5W should be 5W (though there is some variation within specifications) - as it's the cold rating of the oil.
20 will be thinner than 30 when hot.
0W would be better but I have an oil burning early 1ZZ so I'd rather not use an expensive oil
If it's already burning oil, a thinner (lower hot "weight") oil will only burn more oil.
I wouldn't go 20 if the engine isn't designed to take it.
I might try it in Hägar, as I don't care about the bugger anymore
Going down to a good quality 0W oil in winter shouldn't be much of an issue.
