Neutral coasting engine-on should be fine.
DFCO should work, just manu-matic downshift to keep it engaged. But in most cases, neutral will give you better results.
EOC - check your manual for towing instructions. If it's ok to tow with 4 wheels down, you're fine. If it requires a tow dolly or trailer, don't do it.
